I feel that my Yukon drives fine..... smooth...... But, I wonder if getting a fresh set of plugs ( even coils?)... Might make it better? I have no idea how old my stuff is....
The stock plugs and wires of an LS are generally "good" for 100-150K. But, it depends on the condition of the engine and its operating environment, which, as you know, inspecting the plugs can specify. With an LS, I'd definitely inspect the plugs if I had never done so. Not so much to replace, but to compare the cylinders due to the PCV system. Coils tend to either work or not. If you were so inclined, you could spark test every cylinder to look for a variance to identify a weaker coil. Otherwise, it's just the plugs and wires that are the wear items.
mountie
Thanks for the coaching...... What were those REALLY nice wires? ( round coils)..
....and I suppose to replace plugs with OEM? ( plug numbers?)
I guess I'm a bit lazy to search the recent posts. My bad....
  • coil : wires.JPG
    coil : wires.JPG
Are those wires original? I can't make out the lettering. They look blue.
You can't beat OEM wires and plugs. They last +100K miles and, if they're good enough for modded Corvettes, etc., they're more than sufficient for a stock 5.3 in an SUV. Surely you'd know better than to fall for the gimmick plugs. I believe yours came from the factory with platinum plugs. In all honesty, old-fashioned copper plugs perform best as far as producing spark. They just require more voltage to spark and don't last nearly as long as the platinum, iridium, etc. variants. With the platinums, etc., the loss in sparking power is a small compromise when you don't have to replace them every ~30K miles.
As for aftermarket wires, I've never been let down by Taylor. On past vehicles, I've had issues with MSD (I think a few of us here have) and Accel. I'd stick with OEM, but would get Taylor if I wanted a pretty color. Last I checked, they tended to be the same price, if not cheaper than AC Delco Original. Actually, I've been wanting to replace my wires but just haven't bothered.
mountie
Thanks... " If it ain't broke..".... I'll check out Taylor....
As for MSD..... C R A P....... Unless they are from the specialty racing plant. ( My buds in the NHRA world world will never use MSD standard junk in their personal cars.
My old '88 GMC truck, MSD caps & wires failed 3 times in 3 months as I replaced them each time.
Cool LEDS. You finally gave those useless slots a purpose.
They actually do have a purpose. They’re there to let the pressurized cabin air out so that when you slam a door it doesn’t pop your ear drums. There’s rubber flaps behind them on the body that act as a one-way valve. Air can come out but not in.
rmastro
