YukonXL04
The Riverboat
Arlington, TX
I went ahead and bought these floods for my reverse lights.
http://www.amazon.com/gp/product/B00GLLW3AM/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
All these style look pretty much the same size. I'll measure and let you know the size when I get them.
If I like them, I might try to do the same thing you are and replace my fogs. Thinking the spot version would be best for that.
Cool! Are you going to put then where you put the halogen ones?
I have new fog housings and fusion projector fogs to retrofit for my fog setup. Will have 6 hid projectors up front when all said and done lol
SRTH8R
Littleton, CO
Idk, I can only find them on 05 and 06. Maybe they changed it so they only had to make the esky glass. Esky got a giant 3rd brake light, and the rest got the appliqué thing like yours. Can't get it seperate, comes with the glass.
seven9st surfer
Milton, FL
Well, the halogens are kinda ghetto-rigged in there. I managed to wedge them up in some slots in the bumper, I didn't really feel like drilling. Plus, if I had drilled, they'd be sitting really low. I wanted to keep them as high as possible. Hopefully with the slim LED lights, I'll be able to really get them up there. Maybe even hidden.
And I'm unfamiliar with the fusion projector fogs. I've wanted to replace my stock fogs forever, but never found a projector/HID that would fit in the stock holes. You have a link?
BaMaDuDe87
Bama
New air filter and wiper blades all around. Also took off the front wiper arms, and wiper cowl to attempt to chase down a leak. Getting my ass kicked so far.
NCTyphoonKid
Trinity, NC
On my 01 I back flushed the heater core, replaced the other plastic fittings on the heater core outlets since they started leaking, tried to reset the actuator but it kept going between hot and cold so I think its time for a new one so I got the heat stuck on hot for now so hopefully no more freezing :) will replace the actuator soon. The 00 I drove by the shop today supposedly the trans is done he just has to put it in.. needless to say I'm completely fed up with it since it'll be a month Wednesday and its been sitting in the same spot since the trans got pulled (2 or 3 days after I dropped it off). Hopefully he'll have that done if not I'm probably going to wind up going and picking it up and taking it somewhere else or finishing it myself. Needless to say I've learned from this mistake. :angry94:
zieglerj-pdm-specialist
in 100 degree sandbox
Where do I begin
23" Rims rapped with Kuhmo tires, Built a ten inch box to fit in the rear panel so it looks stock but with bass Rockford sub and Rockford sub, Bought HID low/Beam and Hi/beams' Bought a back rear light with all the lights. Bought a hood scoop for the look. A rear view camera for my Alpine. Neon lights to put in my custom grill.
seven9st surfer
Milton, FL
whats the dimensions of these, looking for some small led cubes to replace the crap, stock fog lights.
also would like to do some hidden reverse lights like mentioned above.:happy160:
Dimensions of the ones I got are 6 1/4" wide, 1 5/8" tall, and about 2" deep. Definitely smaller than the stock fogs.
Got them installed, and I'm pretty happy. They're 6000k, so they don't match the 5000k LEDs in my housings, but I think the brightness more than makes up for it. And I was skeptical about how it would look during the day, but I think they blend in pretty well.
Like I said, only thing that could make these better is if I could find a 5000k version. Anyone know where I could find some?
YukonXL04
The Riverboat
Arlington, TX
Wow those sure are bright lol. I got mine mounted up and wired into the trailer harness... they aren't working... gonna have to break out the meter and see why.
seven9st surfer
Milton, FL
I tapped directly into the stock reverse wire for my positive, and drilled in 2 self taping screws into the bumper for the negatives. Good luck.
BMPGBH
