02 Burb
California
Wow those sure are bright lol. I got mine mounted up and wired into the trailer harness... they aren't working... gonna have to break out the meter and see why.
Before you remove it try tapping your brakes to see if they turn on. I made that mistake and ended up blinding people everyone :sorrysign:.All i remember is the ground isn't black and power isn't red lol.
edit: I looked reverse power is purple wire, Ground is white wire. Oh i also had installed yesterday new Bistein 5100s front/rear and rear springs.
YukonXL04
The Riverboat
Arlington, TX
I tapped directly into the stock reverse wire for my positive, and drilled in 2 self taping screws into the bumper for the negatives. Good luck.
Okay... this is going to sound silly but mine just refuse to work... which wire from the led lights are you using as a positive? The red or black?
02 Burb
California
Its pretty easy to use the trailer harness wiring, just tap the positive to the purple wire(reverse wire) and the negative to the white wire. If you want to use the reverse from the taillight then take off the tail light assembly then grab the reverse light bulb and use the wire that is attached to it and splice a wire into that wire for power. For the ground(negative) wire find a bolt that you can ground it out at.
Rangel
Great State of Texas
dimensions of the ones i got are 6 1/4" wide, 1 5/8" tall, and about 2" deep. Definitely smaller than the stock fogs.
Got them installed, and i'm pretty happy. They're 6000k, so they don't match the 5000k leds in my housings, but i think the brightness more than makes up for it. And i was skeptical about how it would look during the day, but i think they blend in pretty well.
Like i said, only thing that could make these better is if i could find a 5000k version. Anyone know where i could find some?
nice!!!
seven9st surfer
Milton, FL
Red for positive and black for negative. With that said, depending on what wires you tap into, it might be worth flipping that, just to make sure.
YukonXL04
The Riverboat
Arlington, TX
That may be the case for 02, but 03+ it isnt.
On mine light green is reverse and black is ground at the trailer harness. However my trailer reverse light fuse keeps blowing. Its grounding out somewhere along the line, not sure where.
I have tried hooking up both lights to the reverse light wire and it trips too. however if I power each light up directly to the battery they work, so Im thinking something is jacked up in my wiring somehow... I soldered and heatshrinked everything so not sure. Gonna yank it out and rewire it and see what happens. Maybe I got a bad piece of wire... lol
01TX_Tahoe
Semper Fi
Pasadena, TX
Installed new brakes on the front, slotted/ported rotors and new carbon fiber pads. Sprayed my grille with Flexidip and sanded my billet bowtie, bumpers are next!
ryan04z71
Haven't been on in a while. I plasti-dipped the bowtie and some of the grill back last September. Still holding up great
BMPGBH
