It's a set of these, I bought them knowing I would do a retrofit eventually. I'm throwing in some morimoto d2s 4.0 square projectors for low/hi and debating an led highbeam.@Leo1103, what headlights are those and what are you upgrading to?
I will definitely need info from you then. I just bought a set of these about a month or two ago. Not bad lights, but would love better light output. Do you have a thread on this or a build thread?It's a set of these, I bought them knowing I would do a retrofit eventually. I'm throwing in some morimoto d2s 4.0 square projectors for low/hi and debating an led highbeam.
Off the bat if you order from trs the harness they give you isnt long enough. Other than that the morimoto seam splitters were pretty helpful but not 100% neccessary. It's not a crazy difficult process as long as you have some fabrication background. I'll post up some pics of the brackets I modified (cut apart with a dremel) once i get everything together. Currently waiting on another order from trs because i forgot a few things the first go around.I will definitely need info from you then. I just bought a set of these about a month or two ago. Not bad lights, but would love better light output. Do you have a thread on this or a build thread?
I've seen the trs kit and it's base is $50, then by the time you add other stuff in, it's a lil over $200. I wasn't really sure as to what I should get without going overboard. I don't need fancy stuff, just better light output. Other shrouds and all that jazz I didn't need or wasn't sure if I needed. I'll look at it a bit more.Off the bat if you order from trs the harness they give you isnt long enough. Other than that the morimoto seam splitters were pretty helpful but not 100% neccessary. It's not a crazy difficult process as long as you have some fabrication background. I'll post up some pics of the brackets I modified (cut apart with a dremel) once i get everything together. Currently waiting on another order from trs because i forgot a few things the first go around.
I went all out and got the full d2s 4.0 kit, I think I was around $350 after discounts and everything but I got a bunch of extra stuff that isnt really needed. I was eyeing the retroquick kit but decided if if was going to crack open the headlights I might as well go all out.I've seen the trs kit and it's base is $50, then by the time you add other stuff in, it's a lil over $200. I wasn't really sure as to what I should get without going overboard. I don't need fancy stuff, just better light output. Other shrouds and all that jazz I didn't need or wasn't sure if I needed. I'll look at it a bit more.
