RooTBeeRthe1st
Not sure why, the tire shop under inflated everything...severely. two of them had to be 5 PSI maybe, one was at 11 and another was at like 21... The guy told me he wasn't sure what to put them at, I would think at least 20 if not 30... Most cars tell you to put 30 plus PSI in the tires from what I've seen.
Anyway
Out with the bald 50,000mi Mud Terrains and 200,000mi 17x7.5 +31 factory wheels.
In with the Mickey Thompson Baja Boss all terrain "suv" tires on the Dorman 17x8 +24 later model steelies. Just enough offset the side walls don't rub the control arms otherwise would have kept the stock wheels.
The ride is super smooth and quiet, but I'm not a fan of the soft sidewall for cornering, I'm sure I'll get used to it. I've only had load range E tires on this until now. These are "STD" rated 44psi max.
I had a tire shop install the TPMS sensor I bought and when they tried to program the others, the LR decided it was dead so I had them install a new one there. But when they brought the truck around, I saw “service battery charging system “ on the DIC. I figured it wasn’t their fault so I drove it home and noticed the volt gauge fluctuated down to 8 and back to 14. I found semi loose connections where the positive wires connect to the post. It had a wing nut on there so I cleaned it all up and installed them with an actual nut so I could tighten it good. No more warnings. I hope that was it.
went out to the junkyard and scored a drivers door handle in good shape, mine the chrome is beginning to peel in the same spot they all do
and rear console cup holder that seems to be working properly and a denali wheel cover all for $36 can't complain
and ordered a new set of tires off of wally world which was a hair under 1k, added a couple grocery items to round it up because my credit card is giving me back $325 in points if I spend $1000 so pfft, can't beat that with a stick, they gave me back $325 last month as well plus $150 in bill credits....
Grady_Wilson
Wyoming
Finally got a chance to wash my Yukon.
It was a little windy but I washed it anyway since it had been months of snow and slush weather to where it looked like I just picked it up from driving around Iraq.
I will have to polish the wheels since they are starting to get some corrosion due to the amount of time between washes.
Feels good to drive a clean vehicle even though it is supposed to snow again on Friday.
Meh.
Geotrash
Dave
Richmond, VA
Thanks for the replies guys. I’ll probably just go with Power Stop’s middle-of-the-line set. Their Extreme Performance are their top-of-the-line set and would run me almost $400 just for all 4 rotors. Yes of course less than Wilwoods ( pads alone for those are $400 or more last time I checked ouch) but like I said, I’m going semi budget so not going for any of the most expensive lines nor for any unknown or budget meaning cheapest either. The other ones I like are the Raybestos Element 3 for around the same price. I’ll decide in a week or so, that’s when I plan on ordering them. There’s an incredible difference in pricing for my truck, from $150- $1500 total for all 4 corners not even counting going with larger front rotors or big brake kits all the way around where you’re talking $4000 or more. Crazy.
I have the Powerstop Z23 rotors and pads on my 2007 and I'm very happy with them. Good performance and no warping.
mastersorbet
