67RS427
Are you happy with your QA1 stuff? I was looking into them when I had my S10. Heard very mixed opinions on their dampers.
The only thing I can compare it to is the stock suspension which had blown out air shocks in the rear and the Bell Tech stuff... It is an amazing ride compared to those. I don't see how it can be bad, you have so much adjustment with the shocks it's just time to tune it how you like the ride. When I first had them in it was very bouncy but after some tweaking to the shock valving it rides like it's on rails... I also don't think the front tires are lifting as much now I have control over the rebound which is the main reason I went with a double adjustable shock. My front tires were lifting off the ground at the track. Still might need to chain it down but it rides so much better it's not even funny...
For those using Android auto, the new interface is live, to enable it, open the Android auto app on your phone, tap the 3 lines in the upper left hand corner, then go to settings, then select the new interface option should be first choice. Your welcome
kbuskill
NE. FL.
Does it change anything from a functional stand point or is it just a new lay out???
I have to be honest... I have only had the option to use AA for a short period of time, since installing the Kenwood... so far I am not a fan... there's not much there that i would use.
it changes the layout, and gives ease of functionality instead of having to maneuver thru different menus it's all on the same page, if you are on waze and listening to sirius it now gives you a pop up of the song artist and title when the song changes, and there is now a small button menu to play/stop/pause music in the corner, I haven't messed with too much yet just did the change this afternoon, thought i was going to have to wait for the update to push thru to the phone, but I asked the google assistant by voice "how do I update android auto" and it told me about the menu that is there now that was not just a couple days ago. so far it's much better
Got it in, turned everything on that I could, it kept the amps in the positive however the temps were much lower today than they have been, I insulated both battery's so maybe that might help a little, got the plug wires installed, it's running smooth I need to take it for a drive and warm it up and see if does anything different
Adamwynn
