kbuskill
NE. FL.
Had my son fix a very small leak on one of the hoses going to the transmission cooler. It was just barely leaking enough to show up on the air dam below the front bumper.
Clearanced around it a little bit and replaced the short section of hose from the hard line to the aftermarket cooler and all is well.
Also collected an oil sample for Blackstone labs. I run extended OCIs and Blackstone wanted a sample at around 6k miles to compare everything else to.
Topped off the oil and transmission fluid and drained the oil catch can... got 2oz out of it... actually measured it this time with a paint mixing cup that is marked.
I normally only drain it when I change the oil at around 13k-15k miles but was curious to see how much was in it at 6k miles.
I really need to order some red wrinkle paint so I can get that new valve cover I got from @iamdub put on the Burb to hopefully alleviate some more of the oil vapor.
lowh07
Nice! Looks great!
thanks. Pretty easy to work with and all of the corners came out mint. I took my time but felt myself starting to get impatient. That’s usually when I start screwing up so I called it quits for the day. It’s a pretty perfect match to the arctic white too
Geoffsfas10
St. Louis
Very happy with how the vinyl came out. Still need to do the door trim and maybe steering wheel.
That looks awesome!!! im not a fan of all the fake wood thats in mine. I like the brushed stainless the vent parts are, thought about seeing if I could match that, or do like you did and match the exterior color
Jay_Rye283
