wjburken
Eastern Iowa
Crawl under and give the starter a light tap with a hammer and see if she starts... if she does the brushes are probably getting stuck so it would be time for either a rebuild or replacement...
That brings back memories. I had a 1976 impala that had a starter that would hang-up once in awhile and no money to replace it for a while so I carried an old night stick that I would use to reach under the car with and hit the starter a few times and it would pop off. Kept in my trunk even after getting it fixed and getting different cars. Not sure how many people I helped by rapping their starter with that thing.
Bigkevschopshop
Northside H-Town
The old words of wisdom live on... Told a guy about this to get his fired up one time... told him to hit it with a hammer, 10 minutes later I hear ping ping ping... super light taps... I said boy you better put some nuts in that swing... low and behold 2 hard hits and fired up... some things in life you can hit hard.... a starter with a hammer is one of them.... Other one is pink.....
Tried to do a cleaned install and wire up my heated steering wheel the other day and its not working. Ended up cutting off the plug at the end of the clockspring(the one that goes into the harness for gm trucks that where equipped with heated wheels) and running ground and power. I used this to try get power from the side fuse box, but got nothing.
did you try looking at the upfitter guide to find the right wires?
lowh07
Thanks for the input. First I'll check the battery terminals, because that's easiest and could be what's been plaguing a bunch of my electrical stuff lately. If that doesn't do the trick I'll wack the starter...
Kee Fuller
las vegas
SPIS
