did my monthly under carriage inspection, looks like the girdle I put on the g80 has a super thin layer of diff fluid coating it, not even enough to make a drip but looks like it may be coming out of the 2 nuts that tighten on the bearing caps I guess I will have to get under there and make sure they didn't work there way loose (re-torque) did you ever run into that issue @Rocket Man.
No sir.
St. Louis
I've always used teflon thread sealant on those threads. You can loosen the nut and back the bolt out enough to put the sealant on then screw them back in to put slight pressure on the caps and tighten the nut.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
2001 Yukon SLT
you mean like that white plumbers tape?
iamdjgad29
