St. Louis
Uh, that is teflon tape, and would work, but there isn't much room in this case. The stuff I was talking about comes in a small squeeze tube like locktite and it's like a white paste
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
wjburken
Eastern Iowa
Uh, that is teflon tape, but the stuff I was talking about comes in a small squeeze tube like locktite and it's like a white paste
2001 Yukon SLT
I would use the sealant, not the tape. The tape can have strings come off and have had that cause problems getting into stuff in equipment. I have almost outlawed the use of Teflon tape on equipment we build.
2001 Yukon SLT
hmm ok I assume I can find that at the auto parts store then or would it be in the plumbing section at the hardware store
St. Louis
Yes, it should be available at auto parts stores and even Home Depot. I have a big tube of it from ARP that I got for when I installed head studs on one of my motors that go into the water jackets in the block (Ford 302).
I also use it on my air compressor line fittings and quick connects on my air tools
2001 Yukon SLT
2001 Yukon SLT
cool, hopefully none of the fluid will spill when I back those bolts out that ***** messy it's still soaked in the road from when I made my big mess the smell finally went away, lol
lol you can see it my sig haha
St. Louis
Not much, if any should come out unless you overfilled it to begin with. Does your cover have a drain and fill plug? You could always drain a bit beforehand then put it back in.
I had pretty much the same thing happen to the support cap bolts on one of my mustangs about a month after I installed the support cover. The aluminum was slightly wet around where the bolt goes through and I thought "damn, I forgot to seal those bolts before installing them." I basically backed them out as far as I could (you can't remove them, because the big, flat, pivot head won't fit through the hole), and applied the teflon thread sealant to the threads, then screwed them back into position. Been fine for years...lol
Fluid level should be below those bolts.
imeliasdau
