No, it depresses the schrader valve as you screw it on. There was enough fuel under pressure to fill it up the bottle if it hadn't all leaked out as the hose was too big, needed 5/32 but only had 3/8" and big tie straps. Not enough to squeeze it down. Anyway, will try again later after a trip to Home Depot.
If there's not enough fuel and or pressure, we'll use the Tech-2 to turn the fuel pump on and off until the beaker is full.
https://www.amazon.com/gp/product/B078R8Q6CD/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
FYI: This is two pieces, the barbed end with the schrader valve depressor slips into the knurled and threaded fitting.
That'll work! Thank you.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Took another stab at this today. Took the interior panels off and tried to find this again. I swear it is related to body flex. I took video to share the sound. When I took this I was squatting in the center of where the right side third row seat would be. The sound originates in the body cavity behind the door striker. There is a body mount directly below this point. Fugg if I know!
kbuskill
NE. FL.
Sam Harris
Texas
I would but don’t want to buy old ones with the plastic worm gear that’s ready to snap. Fresh plastic is keen o_O
is that what is wrong with your existing mirror? if so I just bought the china plastic gear off of ebay put it in and good to go, you just need a vice to do the spring part, I didn't even have to take the mirror off the truck, just took it apart, put the gear in and put it back together, it did take me 2 tries the first time it wasn't lined up right inside. in the video I watched the guy did some grinding and etc which does not need to be done at all
Bradford333
