Is there a good ground at the other side? I get 14vdc at the tabs with the truck running and the defroster connected. You could check continuity to ground on that side.
You will show 12v across the entire grid with your meter grounded to the vehicle. But pull off the wires to the defroster and you’ll only get 12v at the passenger side, the driver side is the ground. My mistake was checking for 12v to the grid but with no ground since that tab had no continuity I didn’t see power anywhere on the grid so I assumed I wasn’t getting 12v from the switch. I had no continuity to ground on the ds, since there was no continuity between the wire and grid.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Was that a side you previously repaired with the frost fighter?
No. I only repaired a couple of the grid lines out in the middle. This was an unmolested tab that looked fine, that’s why it stumped me for a minute. I couldn’t tell it lost continuity by looking at it, it looked factory fresh. Just wasn’t making contact. Weird.
George B
¯\_(ツ)_/¯
Yeah, they are soldered on so it’s odd its not making contact.
so what's recommended for a roller cam break-in?
I was thinking standard Mobil 1 with maybe some zinc additive for good measure.
I have 10w30 VR1 racing oil on hand, but i think it's overkill for a roller...
I use Super Tech conventional 10W-30 for the first startup after major surgery on an LS.
Just Fishing
Can't fix stupid
Utah
I looked down at the remaining cam bearings, they all look great and appear to have not moved.
so...
Camshaft has been installed,
Timing gears and chain installed.
Realized i got a little too motivated for the camshaft install, I wanted to clean the top of the block to perfection first... oh well.
Lots of blue paper towels to plug things... :D
Took the oil pump and did some light touchup and blending of the ridges to improve flow...
I didn't go crazy due to not wanting to f with too much of the anodized finish... but it's an improvement for sure. :)
Mocked up the oil pump, about to re-watch a youtube vid on how to check the pump clearances...
My pump for reference is the Melling 10296 (used the Melling website to pull the PN).
Comes with 3 springs
Red is installed
Blue is included
And some Copo Camaro spring
Pumps: https://www.melling.com/product/gm-aluminum-oil-pumps-select-performance/
So the installed red spring says it's +10psi
Included blue "stock" spring says a reduction of 8-10 psi
"Copo Camaro" spring included says "+25psi over the enclosed blue spring"
Thinking I'm going to rock the red spring....
(Regulator has been pulled due to the pump cleanup, so now is the time for me to make the final decision)
Someone mentioned a possible need to put a resistor on the oil pressure gauge sensor?
:angels2:
so...
Red is installed
Blue is included
:angels2:
I think that was @kbuskill who did that.
kbuskill
NE. FL.
@kbuskill
If you happen to have any more information about that little mod.
Resistor type, location/wire, etc.
:beer:
It is in my "Mod" thread... I will see if I can dig it up for you....
Here you go...
https://www.tahoeyukonforum.com/thr...urb-ltz-mod-thread.100141/page-4#post-1204255
This post and the one below it should give you the information you need.
You don't have to use the pigtail extension, but to me it makes more sense than cutting up the trucks harness.
This isn't the one I bought but it is basically the same one...
https://www.ebay.com/itm/323792964944
That and a 300ohm 5-7watt resistor and some wire, solder, and heat shrink and you should be good to go.
You could always try running it first and see if it is needed. In my case it was.
Potent68
