Just Fishing
Can't fix stupid
I've tried a few and all read 1.5-2 MPH slower than what my speedometer reads. I only bothered in the first place cuz I've noticed that everyone is always pulling away from me even when I have my cruise set dead nuts at 80. Before my tune, cruising at 80 had me steady with the flow of traffic. I just assumed the tuner uploaded an incorrect circumference based off my tire's advertised measurements on the sidewall. I measured it with a wire and the difference was 18mm. I corrected it and it seemed to make it worse. So, today, I changed the number 2.5%. The damned app STILL reads 1.5-2 MPH slow.
That's weird, i find those gps apps are spot on.
When i did the c5/c6 brake conversion on my vette, i also needed bigger wheels.
To get the speedometer working correctly i also need to change a little gear.
The vette uses a mix of analog and digital.
The gears are hard to find and sometimes expensive...
Using an online calculator, and finding the tire actual outer size, i made the order.
Gps reports exact match at all speeds.
Where I'm going, i would assume the speedometer reading would vary wider at higher speeds if it were wrong.
Gps app confirmed a match to my speedometer while going 20-infinity
