that lean code would indicate low fuel pressure so would the miss
Is your fuel pump original?Yeah I am thinking wiring fault, bad connection either with the FPCM or the pressure sensor because of the sensor code. And if the control module can’t get an accurate pressure, what does it do then? Worst part is it’s intermittent. You can’t fix what isn’t broken. Could also be the module is heat sensitive.
And I am constrained in my options for diagnosis and repair. Summers we travel and mostly live in RV parks. Vehicle repair is usually discouraged or forbidden on the premises. So when we’re on the road I have to outsource things I would DIY at home.
you could check and clean up the fpcm harness anywhere, walmart parking lot, that's the first thing I would check, testing the fuel pressure is just a screw on valve I think it's called a Schroeder valve on the fuel rail, the fuel pressure tester will come with a couple different universal fittings. $30 diy and you can monitor it for as long as you need toYeah I am thinking wiring fault, bad connection either with the FPCM or the pressure sensor because of the sensor code. And if the control module can’t get an accurate pressure, what does it do then? Worst part is it’s intermittent. You can’t fix what isn’t broken. Could also be the module is heat sensitive.
Seems right to me. The FPCM is known to get water inside it and wreak havoc. A few of the YouTube regulars seal new ones up with RTV before installing them.my guess is the fpcm or fuel pump is becoming problematic
might want to pick up a fuel pressure tester, there cheap like $30 at harbor freight, you should have a I think a minimum of 42-43psi at idle but most will run a tiny bit higher like 45-50 or so if normal.
the fpcm harness are known to get corroded, might want to get under there and inspect it, pull the harness off and clean it up if needed.
Cheaper then HF.I think mine is this one or one just like it
Amazon.com: FAERSI Fuel Injection Pressure Test Kit - Universal Fuel Oil Engine Diagnostic Gauge Tester Set with Fittings, Instructions, Storage Case for Car Motorcycle Truck RV SUV & ATV, 0-100 PSI / 0-7 Bar: Automotive
Buy FAERSI Fuel Injection Pressure Test Kit - Universal Fuel Oil Engine Diagnostic Gauge Tester Set with Fittings, Instructions, Storage Case for Car Motorcycle Truck RV SUV & ATV, 0-100 PSI / 0-7 Bar: Fuel Pressure Testers - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I bet you could check the fuel pressure of a Moto Guzzi with that kit!I think mine is this one or one just like it
ya it cover's old school and new school for the most part, I was going to try and test my neighbors lexus with it but would have had to cut the fuel line stupid thing didn't have port on it and it was routed all weirdI bet you could check the fuel pressure of a Moto Guzzi with that kit!![]()
it is if you don't have to pay tax and buy something else to hit the minimum free shipping total, I don't use "prime" but I do have a resale account so no taxCheaper then HF.
