alpha_omega
Michigan
Got a volt meter? Start checking for voltage starting at the window motor, then the switch, then wherever the switch gets it's power from?
x2 on the volt meter. It’s hard to diagnose from here without knowing what readings your getting from the aforementioned locations (you could also check the Tech2 and see if you’re getting any faults for those items).
What was the update on the fill cap?
*Check
X2, and can we see a pic?
1st Design
(Labeled SAE 5W30)
- ACDelco FC208
2nd Design
(Labeled dexos SAE 5W-30)
- ACDelco FC244 (GM 12643759)
Update was a slightly different design, much cleaner feeling overall than the original version. Seems to seat nicer, whereas the original version sometimes felt like you were going to unscrew the entire fill tube when you tried removing the cap. Plus an updated o-ring and a change to the text/logo as mentioned above.
alpha_omega
Michigan
For those who have not done an engine oil filler tube replacement or the engine oil filler tube gasket/o-ring, here are some photos showing why you need to remove it only AFTER removing the valve cover, otherwise you will damage the plastic cam portion of the tube and potentially mar or mangle up the gasket.
Also, here is a quick way to remove the o-rings (any o-ring for that matter) without damaging it or the part you are removing it from. The key is to get under it from above and then gently apply slight pressure upwards while rolling your pick or small flathead around the ring. Leaning your tool on the lip of the part it’s being removed from ensures your don’t slip and gouge the part or ding/scratch/tear the o-ring. Unless you no longer need it, in which case a pair of electronic snips works just fine.
*note that I put the gasket/o-ring back in place after removing the filler tube from the valve cover. In order to remove the oil filler tube you must first remove the valve cover, then the o-ring, then twist CCW to line up the cam release slot and in order to remove the tube. Installation is the reverse procedure.
7B0D7D57-0736-470E-B34D-53DA0657ADF4.jpegF46FE0A4-405D-4B7A-AE40-E5921C4E58EF.jpegA1E0051B-6525-4224-98ED-D6E5141C9267.jpeg86955BA5-F44B-4D97-9068-67D7F9A9A21B.jpeg
St. Louis
*Check
1st Design
(Labeled SAE 5W30)
- ACDelco FC208
2nd Design
View attachment 347508View attachment 347509
Was this for your '02, because my 2012 cap looks like this updated version?
89Suburban
Bull in the china shop
SE PA
View attachment 347510View attachment 347512View attachment 347513View attachment 347514
Look at the difference in our locking tabs on the valve covers. You have 2 at 3 and 9 o'clock and I only have one at 6 o'clock. Mine sucks trying to find the right filler tube to fit snug.
89Suburban
SE PA
Yes this is next. Anybody have a wire diagram so I know what wires and circuits to trace and test?
Interesting. I have removed mine from above by pushing down hard to compress the o-ring and then twisting counterclockwise until it releases. But that’s on my 02. I notice the SM states to replace it with a new one if you remove it., nothing about what you’re saying. I notice it says the same for my 08. They designed it as a one time use part I guess.
Just Fishing
Can't fix stupid
Utah
View attachment 347530View attachment 347531
I should have gotten some pictures of what i did.
But a combination of painting the valve covers, and making sure i coated down in the hole a good 3/4 of an inch, and adding an extra o-ring made my fill tube extra tight.
It was something that just sorta happened when i put it together.
But i ordered a few multi size quality oring kits off of amazon since i hate never having orings on hand when i need them.
One of the larger sized, yet thinner orings from one of the kits was perfect to tighten up the fitment.
If you still need it, i can grab the oring kit i used.
Just Fishing
Can't fix stupid
Utah
When i originally removed mine back in like December, i was greeted by the breaking tab.
The replacement i received was not as tight.
Second time around i took my time and used a pick to remove it.
Luckily i still had my old one, it took some careful precision to find and lift the tab.
Not totally straight forward unless you know where that locking tab sits.
Or maybe the lighting just sucked.
And I should have known after reading all this and the SM. I just went and checked and mine's all crooked. So I ordered an OEM one. I swear when I installed it, it was tight and straight.
shadowid60
