Geotrash
Dave
Richmond, VA
Will trimming the shroud apply to the electric fans that I have? (vs. mechanical fan shroud?)
It looks like my shroud is already flush with the back of the radiator. I'll have to go out an poke around some more to verify.
I also see this Liland radiator on Rock Auto: https://www.rockauto.com/en/moreinfo.php?pk=10331768&cc=3305736&pt=2172&jsn=327
Yes, mine has electric fans, too (it's a 2012). But the part you have to trim isn't visible in your photo - it's the top and bottom of the fan shroud. There's a strip of plastic that seals against the top and bottom of the coils. You can see it in this pic along the left side of the image and in the bottom right of it as well:
Sparksalot
Bastrop County, Texas
I just bought a Coldcase in January. I did not need to trim the fan shroud at all, the way others had to in the past. The end tanks on mine also look bigger, so I'm thinking a running design change has been made.
Correct, the Chevy Forum Decoder has 3.08 listed. I'll get a snapshot later and update this post with the Chevy Forum data.
Here:
I think the issue there is it does not know if the vehicle has k5l or not, on the last page under "tech specs" it shows 3.42 being a option to 3.08
that's dependent on if it had k5l or not
I am probably going order one before summer hits, did you need to do anything with the return line to the reservoir tank? where did you order it from?
Just Fishing
Can't fix stupid
Utah
That tells me something about the company, accepting feedback and actually improving their product vs just going for a money grab.
Then there was the cost of the mishimoto one, not worth it IMO.
Factory radiator can be had for $200 (+/-).
I'm willing to spend a little extra for a nicer one, so i did.
Sparksalot
I ordered it from Summit, and had it in two days.
For the return, I went ahead and cut the nipple from the old radiator, then cut it down to slip into the hose. The actual orifice is about 1/8”.
the_tool_man
Upstate South Carolina
It looks like the Cold Case unit is $464 w/shipping.
The AlloyWorks is $269 w/free shipping.
Is the Cold Case worth the extra $200? Is the AlloyWorks going to last?
Weird. The AlloyWorks price may fluctuate depending on how many clicks it gets. When I checked just now (3 hours later than you posted), the price was $299.
mgladdis
