- Joined
- Jan 3, 2011
- Posts
- 50,295
- Reaction score
- 16,951
Moved @89Suburban
You’re learning, worth it in my opinion…Taking inventory, the best i can until the special tools arrive...
This transmission is amazing.
coming from a 700r4/4l60, this thing is so much easier.
We shall see if i fk this up too.
Glad to hear what I've read about them being simpler is true.Taking inventory, the best i can until the special tools arrive...
Could be the cluster too but unlikely.Did an oil change/new filter.
On the way to the store to buy the stuff I noticed my dash Oil Pressure gauge was reading 20psi higher than normal. it's moving fine, but the values are off, compared to the normal readings last night. After turning off the engine, the gauge still read 24 psi.
It should be 0 psi, with the engine off, right?
I suspect the pressure sender is messed up, and now the sensor is reading the same levels, but shifted up +24psi.
Watch the gauge sweep when you key on but before you start. Then, note the KOEO reading.Did an oil change/new filter.
