So I'm just reporting back on these clips. They fit wand work well but they are definitely much more brittle than the factory ones. Like a harder plastic. I was jacking up my reassembly sequence because I was rushing and I had to pull the panel back off 3 times.
There were 4 or 5 I replaced out of the about dozen factory ones. The new clips broke every single time. And one broke during installation. So just a heads up they are pretty much one time use and be ginger lining them up to the holes in the door frame and installing them. I am glad I had them though. Door panel is nice and snug now. Thanks @Doubeleive :)
I wonder if a small cut on the lip edge would make them more flexible?
89Suburban
Bull in the china shop
SE PA
It's the locking prongs that stick out the sides that break easy when you go to pull the panel back out. I probably got half a dozen pieces lost in the abyss of the bottom of the door. Hopefully won't clog up my drain holes. I didn't have time to fk around with a shop vac, I had to get to work before the place went up in flames LOL.
89Suburban
SE PA
I also keep getting a 12" round wet spot under my driver's side floor mat. Pissking me off. Can't tell where it's coming from.
Mine gets wet on the drivers side as well haven't really looked into what it is yet, one of these days i will have to pull the carpet up and figure it out.
could be from the firewall seal is my 1st guess or something around the wiper arm/motor, need to pull the shroud up and look there as well
Odii
Maryland
Finally got the rear bumper bar replaced with factory hitch.
got a curt 7-pin connector (but didn't come with screws, so need to go get some to mount it)
taking off the old bumper bar, you can see it was actually bent pretty badly, which explained why the old step pad was broken, and why the new one wouldn't sit correctly, as it was pushing up with the bumper.
Wednesday night, I went out for gas and groceries. Hit a hard dip along the way to get gas and did something to a wheel speed sensor or the circuit:
Kinda fed up with the inaccurate alcohol content shenanigans:
Hit a milestone and took pics:
89Suburban
SE PA
:console:
briwesric
