jared999
Over the past week:
Drain and fill Front Diff
Drain and fill rear Diff
Drain and fill transfer case
Install Stabilizer links (front left and right). Mine were completely shot.
These tasks were super easy and I would definitely NOT take it to the shop if you have a few tools and some time..
Looks like I need to replace the rack and pinion so that's up next..
89Suburban
Bull in the china shop
SE PA
Over the past week:
You can buy replacement boots and install them.
Yours? In the GMC?
ya I cleaned it yesterday and tested it many times and it was working fine and then today it's back to being intermittent.
new oem one's are like $25 2587776 which is superseded by 22895545
same switch is used in a ton of years and models.
new one should be here in a few days
Charlie207
LFOD, New Hampshire
Also figured it was a good time (not raining) to swap in that different muffler. The one that came with my cat-back system was basically a header muffler, but larger. It had zero packing material to absorb sound, and the drone was a bit much for the kids or anyone in the back seat.
Grabber an Xcelerator straight-through muffler, and painted it (seems to be pointless...) to match the rest of the T409 system.
Sounds decent, but much less drone.... However I'll have to wait until I ride in the back to see how much less resonance/drone there is.
Startup clip:
Geotrash
Dave
Richmond, VA
Thanks for the tip.
Unfortunately my R&P is showing signs that it needs to be replaced.
Bumps make the steering wheel shake, sometimes its hard to turn. I can turn it more on one side than the other. All signs that R&P is failing..
I replaced mine with a reman from Rock Auto and it’s been fine ever since.
Waiting_to_Dye
