ya I asked the same thing on the phone and he said they do not have a QC guy on Saturdays, go figuregood that you have options.
you'd think a dealership could change u joints and test drive it.
is this what you are talking about, kinda looks like they marked it thoughNot sure on our vehicles, but others I've had, there would be match marks on the drive shaft and on the pinion housing or flange and usually when removing the driveshaft you would re-install matching up the marks.
Those look like weights that were tacked on at the factory.is this what you are talking about, kinda looks like they marked it though
You were right!get the one from autozone it's a big suitcase type kit with probably 10 or more different caps
powerbuilt
You were right!
Had to go back and exchange the first one with a broken gauge.. then it worked. There is an overflow port afterall in the filler neck..
which exits on the bottom here...
so you need this adaptor...
so thank you everyone, your concerns/theories all valid.
block combustion tester turned up negative, but was thinking it only leaks when cold so may not be a reliable test for that type of leak.. took about 5-10 seconds in exhaust stream to show positive..So a small leak only when cold may not put enough c02 in the coolant to show..
will test for leakdown tonight and keep watching my coolant level...
was 105 degrees today, on freeway cruising at 80mph my temps hit 204.. might need the radiator side flaps..
