Fless
Super Moderator
Elev 5,280
This is unbelievable. Whatever "tech" did this should not be allowed to touch a vehicle except for washing them. Looks like they pressed the cross right thru the cap since its bulging ooutward and said ooops....oh well lets send it.
Bet one of the needles fell out of place and the cup was forced over it.
j91z28d1
I don't remember when I was under mine last if they are like that. but older gm cars used a shaft without clips they used this melted in nylon in thru cast holes. when I was a kid I tried to change u joints like we used to do, pop off clips and hammer them out. worked without a 2nd thought but this one didn't move. later a old guy said take it to a machine shop. well we basically had no money back then for stuff like that, but I eventually did. watched them heat it with a torch to melt out the nylon and beat them out. then put new ones in. the shaft was never right again. I tried having it balanced, after a few times they said the ears must had been damaged, it passed their balancer but shook the car to death from 70-100mph.
drive shaft shop talked me into building me one.. it was very expensive to me at the time and nice looking but not much better in the car. I gave up and drove for years like that. young and dumb, no one to tell me any better haha. it killed everything slowly.
eventually I read somewhere the automatic v6 cars used to the same driveshaft as the v8 manual cars. so I hit up a junk yard, grabbed one form a auto car, maybe 20$ back then after spending 100s on nonsense. put it in and smooth as glass. after that when they stated vibrating from to much racing, I'd just grab another. later in life when I got my 96 tahoe, I notched drive shaft vibration in it higher mph, looked under it and saw junk yard marks they put on them, thinking someone had already tried fixing this, I didn't even try fixing it. back then I still had hooks up at dealerships and just got a new one. smooth as glass again.
I do u joints at work on industrial stuff, but I tell everyone to stay away from all that stuff in anything close to stock and buy new from the dealer.
i say all that to say the tech mostly likely damaged the ears beating it or pressing it apart. so that's probably why the new caps didn't go in smooth and broke.
atleast try to get the to install a new shaft, I'm pretty sure they damaged that one in the process.
I did have a working pid in tq for fuel pressure. of course it's wacky hybrid stuff haha. before it cranks the engine it's 60psi, the longer it stays in auto stop creeps up to 63-65. once it starts it drops down to 43, fluctuates a bit down to 41.9 sometimes randomly, doesn't seem like throttle effects it.. long time off throttle decel it creeps back up towards 50 haha.
so yeah, without seeing the target psi, which maybe the tech 2 has. I have no idea if any of that is right.
I think I'll put a pump on the list to change over the next few months. can't hurt. I didn't think about it, but with a constant 60psi off and stopping starting a 100 times a day, leaking injectors would reek havoc in this thing haha. probably wash rings out.
Yes, the Tech-2 and maybe the apps have a PID for commanded pressure and of course actual pressure.
j91z28d1
I got side tracked but I was following along with a guy on YouTube that used a can board setup to sniff out what data pack was being sent and returned from the ecm by scanners for finding pids for stuff like that. I need to get back on that. I really want to find the pids to add to tq app for simple use.
No other mark, but there is a fresh scratch mark corresponding on the other side but I think I found the problem or part of the problem WTF!
I bet they used a Spicer 1350 instead of a 1355 with the right retainers. This is exactly what happens when the wrong parts are used. The spicer kits come with an assortment of retainers of varying thicknesses.
Stop by the house Wes, I've got a pile of the right u-joints, the right tools (J-9522) and a shop press now. We'll knock it out in 10 minutes!
I wish buddy
bad news is a new oem one is no longer available
good news is a dorman one can be overnighted if necessary
Juwan7233
