Knowsknone
Cherry Point
Today I decided to take my Tahoe out and play with her, forgetting about my lid flip, definitely drown her. Though, I did find out that my throttle body butterflies seal extremely well. Pulled the air cleaner, soaked up the water, turned her over a little bit and she fired right up. Thankfully I was able to coast out of the massive mud puddle Haha.
Only real problem, my wiper motor wont turn off. Lets hope its just wet and grounding itself.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
lucky!
---------- Post added at 08:32 PM ---------- Previous post was at 08:31 PM ----------
Finally installed LED interior lights...Wow what a difference. Simple easy upgrade.
yeah? how did you fair with the door switches and head light switch?
96redsport
Altoona, Pa.
Solved my problem of why my ABS and brake light was on.... Apparently you can't replace the indicator light with an LED light... Put the regular bulbs in and the lights went out... These are the only 2 that had any problems with the LEDs, not sure why...
moviewithnotitle
Jersey
lucky!
I probably should have been more specific. I did LEDs in the Dome light and kickpanel lights.
Still working on the door swap, but the bulb is bigger than the opening so some minor trimming will have to happen.
SunlitComet
OBS Jedi-Do Good
i think the rear door switches came out nice and bright. tho i think one failed already. the front switches and headlight switch leds were a disaster incandescent bulbs would do way better and now the mirror switch which is not externally changeable just burned out on me switch is less then 2 years old. i just did the doors and light switch in the last two weeks.
Phantom240
Discovered that the end of my ball joint has been ground off, like the wheel broke off at some point. Strange. That'll be next on my agenda.
Brice25
