chaingun427
OBS Mad Scientist
Mooreland, OK
Use a can of starter fluid to check for leaking gaskets, ensure your injectors are seated and plugs are tight with no frayed wires. White running you can pull injector wires one at a time too, if the mirror doesn't change when you unplug an injector either you aren't getting fuel to that cylinder or your aren't getting spark there.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Gzes
the drifting 2dr
Wichita tx
I got it running but still not fixed. Pulled throttle body off again and put new gasket. Realized the hose that goes under throttlebody to throttlebody wasn't connected so connected it and adjusted throttle a tad bit and was running. Pulled it to road and stumbles bad from stop to 1esrt gear. Had to floor it gurl it stumbled and stumbled and stumbled and finally got a little power. And then drive and limp back home. Glad I was a street away otherwise id have to ditch it and walk home for my dolly
rmodel65
The iac is a common failure on the ranger I replaced one twice on my 98, pick up one from the junkyard cheap and see if it helps
a lot of times you can easily clean them
chaingun427
OBS Mad Scientist
Mooreland, OK
Good god that was the most touching thing I have ever seen a truck write brought a tear to my eye it did
Y2KpewterZ
Oh if only our trucks could talk or write letters to us...
Mine would say please fix this damn exhaust leak lol
SunlitComet
OBS Jedi-Do Good
unknown at this time.
14HoeSSV
