tooslowtahoe
climbed my big butt into the the back seat of the 2dr over the rear seat into the cargo area to pull the door panel off the right barn door since the lock actuator froze and wouldnt let me unlock the truck. pull the rod out of the actuator now i can lock and unlock the door with ease
Mine has done the same thing couldn't find the correct replacement if you do please post where you found it.
---------- Post added at 06:43 PM ---------- Previous post was at 06:41 PM ----------
Installed escalade roof rack removing old
Rack wAs very difficult
retorq
Kingman AZ
Where are all those silly videos of the slow ass trucks here in the OBS section?? I need a good laugh at your 0-75 times.
domer94
northwest NJ
changed out my bank 2 aft o2 sensor and cleared out my P0161. i think i licked it.
installed some billet inserts , replaced worn out tails with nice new standard bulb units.
on the downside ... discovered leaky power steering pump. the bottom of it is wet... hopeully its the pressure line
Y2KpewterZ
Finally installed new y pipe and cats. No more exhaust leaks! But now those heat shields are rattling.
Cant tell if rear main is leaking.. or oil from my leaky drain plug is just being blown all over the pan and bell housing.
And i got the bumper back together.
95escahoe
What brand you go with?
Sent from my HTC One X using Tapatalk
rmodel65
i have barn doors but this should be the part number ACDELCO Part # 11P3 rockauto has it for 45$
BirchyBoy
Its from Muffler Express. I bought it brand new still in the box off of craigslist for cheap.
Did you get the whole cat system as a unit? Did you have to remove much to get it out? I need to replace mine as well.
Y2KpewterZ
Yes, i got it as an entire unit.
Gotta pull 3 02 sensors. 3 nuts on muffler-end flange. 3 nuts on each exhaust manifold. Spray everything with pb blast or liquid wrench and let sit/soak for a day. Do expect to snap studs at the muffler-end flange. I noticed one of the studs in the flange, was welded in. The bead where GM welded in the cat comes in contact with the stud. Kit should come with new nuts and bolts mine did. Had to use heat to get bolts off exhaust manifolds. Replace donut gaskets while its apart too.
BirchyBoy
Gotta pull 3 02 sensors. 3 nuts on muffler-end flange. 3 nuts on each exhaust manifold. Spray everything with pb blast or liquid wrench and let sit/soak for a day. Do expect to snap studs at the muffler-end flange. I noticed one of the studs in the flange, was welded in. The bead where GM welded in the cat comes in contact with the stud. Kit should come with new nuts and bolts mine did. Had to use head to get bolts off exhaust manifolds. Replace donut gaskets while its apart too.
Thanks!
wqshaider
