rolfsent
Cincinnati
Had to climb over the back seat and pull the barn door panel off to manually unlock the door since my 2 month old actuator decided to die. Lock cylinder is also seized so I was SOL. Now to go back to advance and warranty this junk part out...
BirchyBoy
I need to find someplace that can test my key fob. It stopped working a couple months ago. I've replaced the battery and tried to relearn the system to no avail.
Gzes
the drifting 2dr
Wichita tx
Intakes on just got ta put the rest on and do water pump and efans fun day today... Gotta grind a bracke because it hits the intake now. Better be worth spending almost a g on these upgrades and tire
qukon 95
Took rear diff cover and comfirmed i will need a rear end, it's not making noise just to much play ,some shifting from a stop ,metal shavings on magnet and pitted gears. Moved my reverse light HID ballast to the headlight HID until i get the other set to my door , ballast is bad also painted the diff cover red to match the red air shocks
BirchyBoy
Just checking. And you hold the lock and unlock buttons down at the same time for at least ten seconds till the locks cycle?
Yes, nothing happens. I need to find a place that can tell if there is any signal coming from my fob. Home Depot used to have a receiver that could tell you if your garage door opener was working. I wonder if the signal/frequency is similar?
Levi0320
