1BADI5
DMV
Cleaned my TB and cut off that weird sh$t on the throttle body plate
Dneel81
OKC
Took the drums off my 14 bolt SF 6 lug axle today. Ordered disk brake hardware, a welder (Miller 190) and the hardware to make this biotch disk stoppered.
1BADI5
DMV
Tonight it clean the PCV, IAC and EGR
...and order the parts and extractor tool to replace that bloody stupid heat hose quick disconnect shit; its starting to leak, which means its going to break if I look at it right. I'm just going to get the 1/2" NPT x 5/8" barb fitting and go with normal 5/8" line.
Dneel81
OKC
stripped a freaking cover bolt on the 14 bolt today...still trying to fix that crap...
1BADI5
DMV
Just scored a mint set of front seats for my 99 for $175
... and installed some new OEM tail lights with stupid bright LED reverse light bulbs
1BADI5
DMV
In the last 24 hours
- LEDs in the door marker lights (5000k)
- LEDs in the map lights (5000k)
- LEDs in the license plate lights (5000k)
- LEDs in the footwells under the dash (5000K)
o Removed the rat nest hack job security system and the truck still runs (LOL) - Just glad I have a decent understanding of GM Ignitions/TheftLock and Passlock system.......if not it would still not be running
o Removed and replaced then heater hose quick disconnect (w/ 1/2 NPT 5/8" straight barb fitting) on the intake manifold (was leaking). And because I bought the extractor tool....it didn't break; amazing how that works.
o replaced the heater hose from the water pump to the heater core exchange and the hose that used to be the line with the quick disconnect
o Disassembled the dash to install all of the LEDs that are shipping from SuperBrightLeds (based on the How To thread in here.....thanks)
o Cleaned the pass.side of the engine bay and motor........ the drivers side will be fun
Up next --
- new oil cooler lines since mine are leaking like the Exxon Valdez (NEW AC Delco lines (IN and OUT)
- gasket kit for the oil cooler......its also leaking
- new oil cooler fittings (NEW AC Delco) Might as well do the whole F'N system since I'm going to go through the effort of draining the oil and replacing all the lines right....... one shot, one kill!
- 180* thermostat
- install my new front seats and center console from a 99 Suburban. They are so clean they look new.
1BADI5
DMV
^ Busy man right there.
Sent from my Spaceship.
Well Im a maintenance ****, hate things that leak and all vehicles I own need to be ready to drive cross country w/o notice.
And since I have time to do it, I might as well do it all and right.
In August I'm doing the intake manifold gaskets and everything associated with it.
Question for the masses, anyone have experience with that Taylor intake manifold riser/spacer kit....not the throttle body spacer.
It claims 21hp and 21 ftlbs......I understand the logic of the kit, just looking for real world reviews or opinions
1BADI5
DMV
Reinstalled the oil cooler with new gaskets, fittings and new lines. Getting what I believe to be the original oil cooler gasket off from the block was a total bish.......but I always win!
After I was done with the above I finished the job with a Royal Purple oil filter and Royal Purple HMX 5w30
At start up I noted I about a 5 to 10 psi gain in oil pressure at idle
Also sealed the deal on 2 mint front seat and console. When I was loading up I asked the guy if he had the driver side interior door panel....he did, it was also mint and i stole it for $15
Hell of a day I must say.
asdfcars
