What do u drive in
haks310
Got LEDs?
SoCal
3: When under 45mph, driving in hills or pulling a load
OD: Over 45mph+
Also...3 would be Drive.....and overdrive would be "D"......That's why there is an "O" around the "D"
99Yuk
Northern Ontario, Canada
99% of the time 'od', however I just pulled my Sisters Pontiac Montanna on an Uhaul auto transporter(the tandom axle trailer, not the tow dolly) to Toronto(5 hours each way) last night. At first I had it in od with the cruise set to 110, but the truck was hunting for gears all the time, so I dropped it to 3, the rpms averaged around 2300, tps average was 18%, and the engine load average was 24%, didn't drop another gear until big hills came around. As for gas mileage? Didn't cost me anymore than a typical trip to TO, just shy of a tank of gas each way. Blew my mind that I could pull 5000+ pounds running at a higher rpm and not burn more gas. Wouldn't have believed it, if I just didn't do it. I think that dropping it to 3 helped.
haks310
Got LEDs?
SoCal
My 'Hoe even has a sticker on the door jamb that tells me to run in 3 (D) when driving in hilly areas or pulling a trailer.
rxphiler
Charleston, SC
I like to start off in 1st then shift to 2nd...3rd...4th then 5th..... LOL I have a manual sorry could help it!!!!
TheBeast99
i stick with D.
i haven't needed to use 1 or 2, even in the snow. instead i'll kick on the 4WD HI.
