What in-car gauge is most important to monitor?
  • Wideband Air/Fuel ratio
    Votes: 3 14.3%
  • Boost
    Votes: 3 14.3%
  • oil pressure
    Votes: 10 47.6%
  • EGTS
    Votes: 0 0.0%
  • volt
    Votes: 1 4.8%
  • fuel
    Votes: 8 38.1%
  • water
    Votes: 3 14.3%
  • Gas
    Votes: 2 9.5%
  • tranny temp
    Votes: 6 28.6%
  • Vacuum
    Votes: 0 0.0%
  • Total voters
    21
A
AtomicHoe094
Atomichoe094
cleveland, OH
Damn man, sorry. You missed it by one year. I forgot your truck was a 95. Well, if I were you, I'd add a trans temp gauge, wideband, and make sure you have an accurate oil pressure gauge, especially if you're still running the original pump. Without oil pressure, you can forget about having to monitor anything else. You'll have other things to worry about if you lose oil pressure while running your engine.
hahaha no no its fine.. So if i get a trans temp gauge, What numbers should i be watching out for? What is "hot"?
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
It is already in my stock gauge cluster, so I wouldn't consider buying another one!
A
AtomicHoe094
Atomichoe094
cleveland, OH
+1.. i mean i think my 97 yr old grandpa could give the advise to look at a gas gauge. And im sure everyone can state the obvious, cant go anywhere without gas.
TahoeGoBoom
blue interior guy
a bunch of the options are the same..
gas/fuel,
boost/vacuum.
just sayin.
and in my truck, i like oil pressure, engine temp, and gas.
but it all depends on the car.
tbh, i keep an eye on most of em. theyre there for a reason. its just what you need to add.
thumper_ehhhhh
Canada ehhhhh
I tow alot so tranny guage is very important. I had a autometer one in my astro but im leaning towards a aeroforce one. My buddy has a different one i'm also looking at it's all digital more compact than the areoforce one. If I remember next time I see him I will get the name of it.
Ok I found in in another thread it's a dashhawk Same idea as the aeroforce one but seems to show more things on the muilti level screen. I like the limits setting option you can use to warn you of getting close to your set limits. He recomends it. This is more than likely the route i'm going to go.
allenaa25
