What is the best way to seal aftermarket head lights?
T
thingraylinetah
Crossville Tennessee
Everyone tells me I am crazy because I want to lower my 4x4 tahoe but if I do a 2/4 drop in the rear or something there abouts it should still have plenty of ground clearance.
davidavidd
CO
Hello, butyl sealant tape this is the best sealing method I have found so far. However, keep in mind that all lights must have a breathing hole for condensation to escape through, usually a circular hole covered with a black membrane. There are NO vacuum sealed lamps o_O
Product:
To seal the lamps you need the butyl tape and a heat gun (or a hair dryer as a homemade solution). The tape softens like putty, you seal the lamp, and then the butyl hardens again. To open the headlights, repeat the process in reverse.
PS: Use gloves, is a very difficult material to remove from your fingers and nails.
T
thingraylinetah
Product:
Thanks for the good advice.
ScottieGirl
