What I've been up to
S
shsportsfan12
Couldn't decide if I wanted my wheels like this
or
Both would provide great traction :crazy:
New steering is made
Angles are still flat as ****
Cranked a lot more then what's pictured here
Honda fits right under
Now it looks like I need bigger tires
Tis all for now
S
shsportsfan12
Finally got the Compression struts in. Had to remake them....Started the shock hoops on Saturday. Everything minus anything 4wd should be done by late Thursday. Leaving for Pismo on Friday....2wd of course.
Modded
That Guy
Looks good and interesting man!!!
You def. need bigger tires to make that Silvy pop off?
Was the negative camber in the pic caused by worn suspension, and what about the Cali?
S
shsportsfan12
No bigger tires....at least not now. I'll find out how it does in the dunes this weekend. It will be getting new wheels with a better backspacing to push the tires out more.
The alignment was due to not doing anything about it when we put the lift on basically.
As for the Cali....I can't afford new springs out back, so I did a shackle flip, 2" shackle, 1" Zero Rate, stock springs w/ AAL. I'll throw some 4" leafs back there eventually and maybe 2 " Zero rate. I need to rotate the axle so we'll see what I do when I get around to that....I have no clue. I just want to get it driving at the moment. Haven't driven it in over 3 months now.
Judef
