BrianBrianBrian
- Joined
- May 30, 2016
- Posts
- 10
- Reaction score
- 1
This is going to be a long one so bare with me....
1998 2dr 4x4 LS Sport
168,300 miles
All items below are new.
I've been driving it around for a year now with with no problems other than a P1870 code which is next on my list of things to fix (TCC regulator valve - Fitsall). While it drives ok, however, it really feels sluggish and a need to press the pedal down just to climb a short hill from a stop. While in this process the exhaust sounds much different almost louder than what I remember from before all these new parts. Now that I think about it, it almost feels like 1st and second gear is absent, but there's no way??
When the engine was installed,
A mechanic friend of mine set the timing with the old finger test... starts just fine. My scan tool says timing advance at idle is 21.5. Not sure if this is good or bad? or can it be improved?
He also installed the new spider Injector. Could this have been installed incorrectly? If so would it still be driveable as I've been driving it around for a year now?
I've seen where some folks have pointed to a fuel filter as a possible cause?
Does anyone think it could be related to me fixing the P1870 TCC regulator valve. I don't see how that would have any effect on the power?
Is there a way to use my OBDII scan tool to diagnose the problem? I've tried searching the entire internet for the correct computer readings on a 98 tahoe should be at Idle and compare them, but to no avail. Oh, and for the record, I just passed emissions!
In any case I'm at at a loss as to where to begin. I would be so grateful to anyone that could brainstorm this with me! I've attached screenshot of the codes that my scanner puts out if that helps.
Thanks Brian
168,300 miles
- GM Goodwrench 1996-2000 Truck 350ci/255HP 5.7L Engine
- BWD Fuel Injector - MFI
- Spectre Performance HPR8038 Air Filter
- Dorman 626-105 Heater Hose Assembly
- Stant 45119 SuperStat Thermostat - 195 Degrees Fahrenheit
- ACDelco 19244500 GM Original Equipment Engine Oil Pressure Sensor
- OEM 8824 Neutral Safety & Reverse Light Switch
- Dayco Belt Tensioner
- Duralast/Crankshaft Position Sensor
- Duralast Gold/Starter
- ACDelco 335-1068 Professional Alternator
- Bosch 09768 Premium Spark Plug Wire Set
- Automatic Transmission Flywheel Flex-Plate
- Torque Converter, 700/4L60/65E, 298MM
- 4L60E Rebuild kit, M. W/S, 97-03 FIBE
- Filter, 700-R4 82-93
- Band, 4L60E 2-4 HI ENERGY
- Plate VB Seperator 4L60E
- Ignition Distributor for GMC Cadillac Chevy Pickup Truck SUV Van V8 5.0L 5.7L
- ACDelco 214-1080 GM Original Equipment EGR Valve
- ACDelco 41-993 Professional Iridium Spark Plug (Pack of 1)
- Dorman 800-401 Heater Hose Quick Connect
- Delphi AS10015 Ignition Knock Sensor
Thanks Brian
