optimusprime
- Joined
- Jul 15, 2016
- Posts
- 107
- Reaction score
- 29
What is this doohickey and why does it make the most annoying vibrating sound ever all the time?
asperator, provides temperature to computer. Replace if the noise is bothersom to you. Requred for automatic AC operation.What is this doohickey and why does it make the most annoying vibrating sound ever all the time?
Pull that cover and clean the hair and dust off the fan blades. If it doesn't work, get another aspirator, 22834330. If it fails, your Auto AC won't work right.What is this doohickey and why does it make the most annoying vibrating sound ever all the time?
it's the NSA wire tap inside your SUVWhat is this doohickey and why does it make the most annoying vibrating sound ever all the time?
environmental sensor for the hvac to properly regulate the interior temperature. it has a small fan and a thermistor, the fan motor goes bad and makes the noise. the fan blows air over the thermistor and changes ohm's the ohm signal goes to the hvac, the hvac then adjusts the temp up or down to keep the temperature where you have it set.What is this doohickey and why does it make the most annoying vibrating sound ever all the time?
Anyone still finding these for $25?environmental sensor for the hvac to properly regulate the interior temperature. it has a small fan and a thermistor, the fan motor goes bad and makes the noise. the fan blows air over the thermistor and changes ohm's the ohm signal goes to the hvac, the hvac then adjusts the temp up or down to keep the temperature where you have it set.
a new replacement is about $25 online and is easily replaced by both unclipping it and reaching in from the side of the headliner.
just pull the side of the headliner down "carefully" just enough to reach inside
Not with inflation. There's one on ebay from a low mileage vehicle for $31 and another new one for $44.Anyone still finding these for $25?View attachment 428215
