DuraYuk
- Joined
- Sep 17, 2022
- Posts
- 864
- Reaction score
- 617
Lol you are funny.Definitely NOT a 2021-2023
Apparently they have special wiper blades that can ONLY be bought from dealer/OEM
It might be time to break out the expensive tools and start working through it. I'd loose my shirt if I gave up on my yukon, it's paid off as of last month. Haven't been able to drive it in a year.. I'm determined to have an error free truck at this point.Thanks, I am up north. I do garage my vehicles and wash them regularly. I wish I could just keep what I have, but this electrical issue is out of hand. Nobody sells their vehicle because they love it. I guess I could always get an extended warranty.
It’s a top lock push design. Not your typical j-hook that everyone is familiar with, but nearly every aftermarket wiper blade includes the adapters to adapt to TLP. When you buy new wipers you get little pieces of plastic that you always throw in the garbage. One of those is the adapter you need.Definitely NOT a 2021-2023
And the blades are only $24 each…this really the reason to not getDefinitely NOT a 2021-2023
I would just invest in new battery cables, starter cable, clean the grounds and add a couple extra of your own grounds in good spots.I have no choice but to trade my 16 Yukon in at this point. Between the no click no start, and the continuous electrical drain that we are unable to find. I cant keep paying this much for something that sometimes starts, especially with winter coming.
I thought this would be easy and I would buy a new Tahoe RST but Im not loving the lack of amenities in it. The dealer showed me a 19, but looks like they also have some serious electrical issues as well.
Does anyone have a year that they can recommend that seemed ok?
Thanks
My post was sarcastically referencing a post by @Blueinterceptor in the UAW strike thread about certain models taking special wiper blades that will be hard to findIt’s a top lock push design. Not your typical j-hook that everyone is familiar with, but nearly every aftermarket wiper blade includes the adapters to adapt to TLP. When you buy new wipers you get little pieces of plastic that you always throw in the garbage. One of those is the adapter you need.
Check RockAuto - there’s a ton of wiper blades that will fit the ‘21+ platform.
Serious lack of ground clearance tooDefinitely NOT a 2021-2023
Check the grounds. Then check the grounds. And once done, check the grounds.Suggest taking to an independent shop and maybe have someone check all the grounds…GM notorious for bitching the ground system and it causes all sorts of bad and hard to diagnose stuff…
