Wheel interchange
DallasTahoe
I've got a 98 GMC Yukon and I'm wanting to change my wheels to a newer style oem set of wheels so I can go with larger diameter tires since I can find them pretty cheap with pretty good tires, so what years of newer oem wheels will fit on my obs?
adventurenali92
Big Bear Lake, ca
@DallasTahoe, I'm assuming you have 6 lug pattern wheels correct? If the rim you're interested in has the same lug pattern as your wheel than you can use it. If you're interested I have a set of 17 slt rims that I have no need for and are taking up space haha. I'll sell them cheap,as I just want them outta here. They are brand new.
DallasTahoe
DallasTahoe
Yea I have 6 lug but I also have 4wd that's the main reason I wanted to know if other wheels will fit. What do those slt rims look like?
adventurenali92
Big Bear Lake, ca
Split spoke aluminum wheels. They are brand new and never been used. A client dumped them on me and I have no use for them.
ScottyBoy
Shreveport, La
Yes, the older 6-lug 4wd lug pattern is the same as the newer 6-lug pattern. So pretty much any GM full sized 6 lug wheel will fit. I said "full sized" because Trailblazers and Envoys are not full sized and they do have a 6-lug pattern that is different from the full sized truck and SUV lug pattern. So pretty much any 6-lug wheel off an Escalade,Yukon, Tahoe, Burban, Avalanche, Silverado, or Sierra will fit on your 98 Yukon.
DallasTahoe
DallasTahoe
Cool thanks for the info, that was what I needed to know
DallasTahoe
DallasTahoe
Make me an offer. I need the space that they are taking up haha. I'm in southern California. Shipping shouldn't too big of a hassle since they don't have tires on them.
Let me think about it
jason05
