you think that is the issue it will just crumble over time or break with in a short time of installing itNo shit? Stored in the shade / climate controlled?
the two spots where it typically cracks are high stress spot.. the panel closest to the windscreen puts a LOT of down force pressure on it despite only weighing 2 pounds
more then like the A plier panel is putting a lot of pressure on it and transferring it to the dash
a mistake was made when they designed the small panel... the error was only slight. Seems like a OCD error
I noticed the heavy down force pressure while repairing it i could use JB weld but would be pointless since it will just crack somewhere else close by..
the repair was NOT successful because of the heavy pressure
tell you solve the pressure issue it will keep cracking once the sun breaks down the plastic or if there is a frame flex (expansion/contraction cycles)
