Where to buy various interior trim pieces?
derekjl
Where to buy varios trim pieces?
The driver's side door panel on my 1999 Tahoe is loose at the very bottom by the plastic pocket and speaker. It looks like there are several white "plugs" that go into the steel portion of the door itself. I have the same issue on the felt pad on one of my rear barn doors, part looks similar. Where can I locate these parts besides a dealership? Does anyone know the process of installing them? Hopefully I wouldn't have to take the entire door panel off just for this. I also need to locate the plastic flip don't piece for my sun visor. It has broken off and now the vanity light stays on all the time unless I wedge something up there. Thank you!
Tahoe14
Central Fl
You would probably have better luck posting in the 1991-1999 section. Good luck.
D
derekjl
Bump
SunlitComet
OBS Jedi-Do Good
unknown at this time.
there are plenty of fasteners out there. but finding the 2 pieces that go together in the same part bag may not happen. won't cost you hardly anything at a dealer.you stick the peg in the slots on panels and rotate it 90 so it holds itself in place. it then inserts it self in to the other piece which mounts on the door frame. for the visor either buy a whole new assembly or scavenge jy's for it.
D
derekjl
Update: looks like I got the fasteners for the rear barn door situated. I just pulled them out of the door frame, reinserted them to the panel and twisted. Didn't know it was that easy. It looks like some of the spines on the plastic plug are fractured or missing, is that ok? They still grab fine when inserted. Now I just need the ones for the front door panel. Looks like 2-3 were missing. So these are readily available at the dealership? I know Dorman makes them but I like to go OEM whenever possible. Thanks!
D
derekjl
should be fine. yes.
Cool, thanks. I noticed that the ones on the very edges of the trim just slip into the hole in the frame and didn't have anything connecting them. Is that how they are supposed to be? Can someone confirm the P/N for the front door trim retainers as 15960325. Thanks!
Mirek
