Where to buy weather strip
novemberr
Hello,
My truck is 2012 Yukon Denali XL. It rained a lot recently. I found the water around the front passenger door sill and wet carpet as well. I guessed the weather strip may need to be replaced. I searched and found that the both rear sides are the same part #(22766375). The front are different 22766409 and [URL='https://www.gmpartsonline.net/oem-parts/gm-surround-weather-strip-22766410/?c=Zz1ib2R5JnM9ZG9vci1hbmQtY29tcG9uZW50cyZpPUdDMDc3MDA1JnI9MyZhPWdtYyZvPXl1a29uLXhsLTE1MDAmeT0yMDEyJnQ9ZGVuYWxpJmU9Ni0ybC12OC1mbGV4']22766410[/URL]. Does it sound correct? Where is a good place to buy quality weather strips?
Thank you for help.
Here is the link I found.
https://www.gmpartsonline.net/auto-...flex-engine/body-cat/door-and-components-****
PG01
Up here to the right
Do you have a sunroof? Normally they leak from sunroof or sharkfin antenna... i would check those areas before replacing door weatherstrip. Also, make sure your door isnt full of water leaking into cabin. The drains in the bottom of the nnbs doors get clogged, door fills up with water and leaks into cab..
N
novemberr
Thank you for the hint. I opened headliner. The sunroof is dry. There is no water from top.
The drains at the bottom of the door are good. There is no water mark on the door.
I took a picture. There is no water under sill. I guess the water is from weather strip leaking.
N
novemberr
Thank you. They are very confident with their price. The price are indeed the lowest I can find.
Those part #s are for rubber strip. I took them from the link in post#1.
N
novemberr
The ground shipping is $50 in gmpartsonline.net!! I need to find my TI-86.
Elmo
Hello,
My truck is 2012 Yukon Denali XL. It rained a lot recently. I found the water around the front passenger door sill and wet carpet as well. I guessed the weather strip may need to be replaced. I searched and found that the both rear sides are the same part #(22766375). The front are different 22766409 and 22766410. Does it sound correct? Where is a good place to buy quality weather strips?
Thank you for help.
This looks right as far as the weather strip. If that does not fix it make sure your AC drain is not plugged. If it is that will soak the passenger side wheel well.
GranPrix
I just bought these and swapped them out yesterday.
