where to get hids installed in minnesota
yukondoit
Stay Classy
Flagstaff, AZ
Yeah just do it man. It will definitely be a major improvement over your stock bulbs. Very easy mod, 30-45 mins tops install time. Keep us updated.
Krunchy
Chilliwack BC
im looking for info on where to get hids installed in mn or a better bulb i can put in my 2005 yukon. any ideas?
If you can change a regular headlight bulb you can do this. Unplug your old bulb find a spot to mount the ballast plug the ballast into the trucks headlight wire then attach the hid bulbs to the ballast then insert the bulb into the headlight housing and your done. If it doesn't light up reverse the connection from the truck to the ballast the pos and neg are reversed on ones made in japan.
Austin12
