Which Transmission Filter do I use? Shallow or Deep?
stefenboy
Hi everyone, I'm a new owner of my 60k miles 2005 gmc denali xl. I want to do my transmission service before my BBTune in January, but am very confused on which pan I have on my 4l65e (m32) transmission?? Do I order the Ac Delco TF289? or the TF339? or is it the Ac Delco 24208576? I am also doing the corvette servo. Did anyone use the complete drop in rebuilt unit from gmtransmission? I was told to rebuild and use my oem shaft with the corvetter servo. Thanks in advance.
Steven
#1taho
5150TAHO
niagara falls ont
If you have a drain plug on the pan you most likely have the deep pan. Which will require the deep filter. I am not sure on part numbers but they will be able to tell you. Corvette servo I have done a few different ways. Depends on what your preference is.
Sasquatch
Orange County N.Y.
You can tell which pan you have by looking at it, If the pan is completely flat it`s the shallow one, If it steps down you have the deep pan.
S
stefenboy
Thank You that is very good information. I'm sure this will help others as well.
wesyder
Eastvale
I have the same vehicle and i use the tf-351 from autozone, its for the shallow pan
drackill1
