Whipple or Maggie?
@sumo did you have to upgrade your fuel pump with a high-flow one? One more thing I've been wondering.
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
No real need for a dyno. If you are concerned, you can always buy an AFR sensor to plus into the AutoCal.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Nope stock pump with injectors that came with blower rated for flex fuel. Flex injectors flows more
Than non flex. No problems, knock or ping when using shell only 93 octane. If you have flex, you want be able to run e 85 according to Justin.
I don't have flex fuel, it wasn't an option in '02. I bought some flex injectors out of a '10 rated at 50 lbs/ hr though. Thanks for the info on the pump.
I can get 3 AWD dyno pulls for $100 though and that will let me know what I'm getting to the wheels also. Although an AFR sensor and gauge would be cool although I have no idea how to install one. Would I have to weld a bung in the exhaust? Also, how would I connect it to the Autocal?
bottomline2000
Dallas, TX
I have an AEM wideband gauge to install. Simple pos/negative connection to a switched ignition source. U can data log your fuel trim thru the egr 5v connection to the ecm since u are not using it anymore using the autocal. The gauge comes with a bung u can have welded into the exhaust.
Sent from my SAMSUNG-SM-T377A using Tapatalk
sumo
rhode island
You can have Justin tune out the rear o2 sensors. I uninstalled a oem o2 and plugged the wideband in there
How do I connect it to the ecm and have the Autocal recognize it? I'm lost there.
bottomline2000
Dallas, TX
Justin said and from what I've found online u connect the wideband to pin 55 on the ecm which is for egr voltage. The autocal plugs into the obd2 port like normal and is reading EGR voltage which is actually the wideband's voltage output of a/f ratio. Conversion looks like this..
SmoothADetailing
