why is the 4l60e such a P.O.S.?!
retorq
Kingman AZ
how hard is it to rebuild the 60e to make it stronger?
If I can do it anyone can ... LOL I did a Superior Shift correction kit, upgraded Alto red clutches, Alto red band, Kolene steels, higher element count sprag, 13 vane pump kit, Vette servo, thicker separator plate, "Beast" sun shell .. I stuck with the 4 pinion planetarys but you can get 5 pinion setups like the 4L65 tranny.
Here's my thread on the rebuild, it really wasn't that bad:
http://www.route66wingsandwheels.com/forums/viewtopic.php?t=288&view_pics=1
---------- Post added at 08:54 PM ---------- Previous post was at 08:53 PM ----------
would a 65e fit in a 1997?
And if i switched to an 80e, would the truck be faster or slower due to the different gears? I ran the numbers but i dont really know about trans gear ratios... all the better if it gives it more go! lol
There are no external differences between a 65E and a 60E, just internal. You can even use the same computer ...
mdiacont322
mdiacont322
Senior Member
hey thanks for the info and the link... do you know about the 80e though? Will the gears in the 80e be a fastr setup than the 60 or 65e?
retorq
Kingman AZ
4L80:
Gear Ratios are:
* First Gear - 2.48 to 1.00
* Second Gear - 1.48 to 1.00
* Third Gear - 1.00 to 1.00
* Reverse - 2.07 to 1.00
4L60:
The gearing for the 700 is:
* First - 3.059:1.0
* Second - 1.625:1.0
* Third - 1.000:1.0
* Fourth - 0.696:1.0
* Reverse - 2.294:1.0
I don't know why wikipedia doesn't list the OD for the 80 but I think it's the same ... the 60 will get you out of the hole quicker vs the 80, from a gear ratio stand point. But that 1st to 2nd shift on the 60 is a steep one. The 80 is bigger so it's more weight to haul around. But of course if you are overpowering the 60 then it's a moot point. :D
mdiacont322
mdiacont322
Senior Member
haha...im just wondering what would be better and more budget effcient... the truck stil moves, so im taking it to the trans shop friday. Its under warranty so if something is bad it wont cost me anything but some downtime, but in the future im wondering what would be the best option if this keeps crapping out on me. its like i have no luck with any of the driveline on this truck... ive gone thru as many rears as trans' :(
---------- Post added at 12:19 AM ---------- Previous post was at 12:12 AM ----------
4L80:
just to clarify... what do you mean by steep? I know i probably sound like an idiot lol.
and the calculator says that the 80e shifts at 10mph higher than the 60e (53mph instead of 43mph)... am i going to notice the truck being slower off the line from an acceleration standpoint?
retorq
Kingman AZ
If I had the money for a 4L80 retrofit into my truck, I would have went that route. When I rebuilt mine @5 years ago there wasn't as many 4L80 swaps running around as there are now ... not to mention, a 4L80 in a boneyard ... around here?! Not happening. If you have the money I say go for it. :D
Look at the difference in the numbers between 1st and 2nd gear on the 60 vs the 80. There is less of a difference on the 80, which means less RPM drop from the 1st to 2nd gear change. I think from a dead stop the 60 will launch better, but that shift from 1st to 2nd will kill ya if you don't have enough RPMs in the engine.
LOL You must be ******* parts, this is only my second rear end. :D
95TwinTT
Minnesota
The 4L80e is just like the "close ratio"4 speeds from the corvettes and muscle cars. True, first gear is taller, but slap in a higher speed stall speed, TC and problem solved for first hear. Once your rollin, the close ratio makes for faster 1/4 mile times. Much more effecient..............
I wish I had done my 80 a few years earlier. I could have saved a ton of money that I wasted on the many 60's I went through. :)
Arctic-Rodz
RGV Texas
Maybe it hasnt been rebuilt properly? I dont think the mods he has is enough to over power the transmission. All he has is intake, exhaust, and a small tune. Not a HUGE power adder.
mdiacont322
mdiacont322
Senior Member
I used to be a lot worse on my stuff lol... it really pisses me off though that im treating the hoe like a baby thats not even born yet and its still giving me problems.
Its kind of like murphy's law with this trans, so im wondering do i spend the extra bucks, put a 80e in, and give up a little bit of acceleration... or do i keep breaking the 60e...
What are some weak points in the 60e that i could maybe emphasise on when i take the truck in if it has to be rebuilt AGAIN lol
---------- Post added at 12:16 PM ---------- Previous post was at 12:02 PM ----------
good point... im not sure if it was rebuilt properly because
1) i just take it to the "mechanic" and he takes care of it (supposedly)
and
2) if i did take it apart I probably would have no idea what to look for besides burnt clutches or a snapped shaft lol
I looked at the power numbers for the engine stock, engine with the programmer, and trans torque limit...
the engine stock puts out 330 ft lbs of torque.
With the programmer it puts out around 40 more ft lbs at the rear wheels, which means more at the flywheel, according to the dyno sheets from superchips.
I have read that the 4l60e can only handle up to 360 ft. so with the programmer alone it looks like it has too much torque, plus the intake and exhaust. Just a thought though.
Im not an expert but by looking at the numbers it seems possible.
BUT... I also have a strong feeling that this guy that rebuilds them doesnt put them together right either, because he was supposed to make it stronger but it just so seems like they keep breaking.
---------- Post added at 12:18 PM ---------- Previous post was at 12:16 PM ----------
i may seem like an idiot... but what does a stall converter actually do? and what did you choose for your tahoe as far as a stall converter and TC?
Arctic-Rodz
RGV Texas
Are you taking it to a "shade tree" mechanic? that may be the problem. I doubt that superchips is squeezing out 40lb/ft of torque with just a tune. That old 350 is tough to get power out of (ive heard). Heads and cam might give you 40.
Stall converter allowes your engine to rev higher before all the torque gets to the wheels. For example, I have a 3000 stall converter in my 08 Sierra. It allows me to stall it to 3000 RPM and it'll launch off the line at 3000 RPM. Hard to keep the tires planted though. It got me .4 seconds off the 1/4 mi time.
All my mods on my 08 Sierra are on the stock 4L60E and she shifts just fine. And I beat it up pretty good. I know im gonna have to rebuild it down the road so I dont beat it up as often as I use to. Theres a Transmission shop here in South TX that will rebuild the
4L60E to support 550+HP for just under $1000. Not bad I say, thats what ill be doing to mine.
newmarketeod
Have you done any other mods like a LARGE tranny cooler in addition to the original, a good high quality fluid or larger tranny pan? Do you have a tranny temp gauge so you can monitor the heat and give us some temperatures you are running at? It seems like a few bolt on mods shouldn't be burning through transmissions like that.
Beefsolar
