why re-gap spark pluggs?
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
I have the TR55s and are gapped at .035. They were at .040 before the supercharger though. GM changed from .060 to .040, there was an advisory that went out with the change.
Max
Mile High
Denver
unless you have a supercharger, turbocharger, or nitrous gap them at .040
withac
Eastern Idaho
I put the NGK TR55's in my 5.3. I double checked the gap but all were at .040. As far as pressing the gapping tool against the center electrode to open up a gap I wouldn't do that regardless of it's size. You can slide the outer electrode through the hole with the larger part of the tool turned away from the plug. You can then gently pry down on the tool therebye lifting the outer electrode away from the center one therebye opening the gap.
tybardy
tybardy
everyone needs a Hoe
Gilbert Arizona
thats the proper way of gapping a spark plugg, regardless of what type of plug you are gapping, you should never "wedge" something between the gap to open it up. if you are using the tool correctly, nothing should touch the electrode other the the act of measuring.
road1will
pretty pretty good
Johns Creek, Georgia
I think i may do my plugs today. I know they say they're fine til 100k miles, but i'd be curious to see if i see any change by re-gapping.
tybardy
tybardy
Gilbert Arizona
the rear two will give you heart burn, but otherwise an easy project... just be carefull removing the boot as these ******* are particularly snugg, ive dont pluggs in several cars/trucks, these were the toughest to seperate plugg from wire i ever ran into. Yuo dont want to rip the wire, then your spending $70 on new wires
withac
Eastern Idaho
I can NEVER remove all the old wires without ruining one, so I always to wires when I do plugs. I actually don't remember what I used, I think it was Bosch. Some people said they didn't like them but I saw at least a 2mpg increase with the new plugs and wires.
tybardy
tybardy
Gilbert Arizona
2mpg increase is HUGE from just pluggs and wires
were your old pluggs all ****** up? did you go with a bigger dia. wire?
withac
Eastern Idaho
Same diameter wire. It had around 93 to 96K miles on it, I don't remember exactly. The old plugs had burned out considerably, I don't remember how much but it was a lot more than .040, big ol' gap.
sportyjames
