Width of push bar for Tahoe?
Nutro
Can someone measure the width and height of a similar push bar meant for a Tahoe? I got this one locally but the person didn't know if it was for an Explorer or a Tahoe.
Thanks!
Edit: Its a Manik? brand so I doubt I'll be able to find the correct brackets for it.
Thanks!
push bars are just mounted into the frame slots where tow hooks normally go, if you have that part then making it work shouldn't be all that hard you just need to make a bracket or have one made by a machine shop
N
Nutro
I was hoping they were all the same width but I figured a push bar for a Tahoe would be wider than one for an explorer? I honestly don't know
N
Nutro
Yes sir, thats why I was needing measurements from a Tahoe unit
opfor2
Riverside County, CA
Thanks!
That looks like a rebranded Gorhino (https://mygorhino.com/) push bar. check out the website and look for the year of your vehicle and go from there.
mikez71
Does NOT look like it was made for a Tahoe.
But if you need to make brackets anyway, you might see if it looks good holding it in place..
PPV_2018
Senior Member
U.S.A.
Sorry I can’t provide solid help but, looks pretty small in the bed of that truck. Like it was made for charger or crown Vic .. maybe even Taurus or other.
I suppose you really just needing to know the length between tow hook slot to tow hook slot? If you’re custom fab’ing brackets anyways you should be able to make it work not even needing the measurements of one purpose built for Tahoe especially if it is not the same physical size. (Not saying it is or it isn’t, but it does look small)
Smityinms
