Wife overheated the 2005. . .
S
strad
Las Vegas
Another update. I've heat cycled it three times now. Lost some coolant level after the first one, but I expected that, happens every time you reload the cooling system in my experience. And I did lose about the amount I expected. The second two times, I didn't lose any level. So far so good. I do need to replace those t fittings though. They are not leaking, but we don't need another disaster.
Edit: and yes, it gets to normal temperature, and stays steady at that temperature. Just below 210 on the gauge, just like before all of this happened.
If you get the plastic T’s make sure they’re AC Delco parts and not Dorman or any other aftermarket plastic ones.
It took me 3 top-offs to get my coolant level stable at the proper level mark on the reservoir. Since then, the level has not moved.
YukonRog
Auburn, CA
Yeah wives right? I think we could all use a chuckle these days and this reminds me of an incident. Back in maybe 1980 my boss was found sitting at his desk just shaking his head at what his wife just told him. Apparently, she had their new Porsche out shopping and it overheated in traffic. So she thought she'd pull into a gas station and cool the motor off with a water hose. Crack! Gotta love 'em.
SnowBuck
OK...now where's MY coolant going??? Have to add about 3/8" to the reservoir every few weeks. Dealer finds nothing. Garage #1 replaces radiator cap and hose clamps. Garage #2 does pressure test = OK. Garage #3 does dye test and another pressure test = no leaks. Oil always looks perfectly good. No white smoke front or back. So after 4 garages...I still keep a gallon of antifreeze in the back seat !!!!!
S33k3r
Dallas, Texas
Check your water pump. It may be on its way out. The weep hole starts losing coolant about the time the pump is going out.
Wife and truck/car overheating stories........
Years ago, before cell phones, my girl friend (to become my wife) was returning home on a remote road in the late evening in the winter after work in her '67 Buick Special with the V6 motor, and her temperature light came on. It was extremely cold, and she made the decision to try to limp home, rather than stop in the middle of a cold winter night on a remote road. Naturally, she drove until the motor fully overheated, seized and stopped. Eventually, a cop came by, stopped, and radioed into the station to call me at home.
I could not really blame her for her decision, as I could fully understand how she felt exposed in this situation. But, since the result of her decision was going to cost me a lot of time and work in rebuilding her motor, I felt that it was appropriate for her to participate in the rebuild. Amazing enough, that V6 motor held up very well, under the seizure, and the only true damages were 2 pistons needed to be replaced. Further, there was minimal cylinder wall scoring in any of the cylinders.
So, the 4 remaining good pistons needed new rings, but prior to installing the new rings, the carbon deposits within the ring channels on the pistons needed to be removed. As such, I gave her the pieces of broken rings from the damaged pistons, and I had her scrape out all of the carbon deposits in the 4 pistons with the pieces of broken rings. This carbon scraping job took several hours to complete, and I can assure you that she was NOT happy about the work. But, like a real trooper, she persevered, and completed the job. In addition, she was present and served as my assistant, throughout the entire motor rebuild project.
Result of the experience: Whenever something goes wrong with her car, or even if she thinks that something might be about to go wrong with her car, she immediately stops the car, and I receive a phone call from her.
So, the 4 remaining good pistons needed new rings, but prior to installing the new rings, the carbon deposits within the ring channels on the pistons needed to be removed. As such, I gave her the pieces of broken rings from, the damaged pistons, and I had her scrape out all of the carbon deposits in the 4 pistons with the pieces of broken rings. This carbon scraping job took several hours to complete, and I can assure you that she was NOT happy about the work. But, like a real trooper, she persevered, and completed the job. In addition, she was present and served as my assistant, throughout the entire motor rebuild project.
Awesome story. :)
Allthingschevy12
