won't start
nick8403
I have a 97 Tahoe 5.7 vortec it was running fine then it just died changed fuel filter and still nothing can still hear pump and getting good pressure to lines behind the throttle body but its not getting any gas in the throttle body can dump gas down it and it runs. What am I missing any help
N
nick8403
What is a fuel spider? And its as good now as it was before it died I'm new to dealing with throttle bodies and all the electronic stuff
SunlitComet
OBS Jedi-Do Good
unknown at this time.
your fuel lines enter a body which, if old style goes into a body with injector valves in it there are output lines with a poppet valve on then end of each one that goes to to an injector runner of it own on the lower manifold. being as there are eight skinny lines stretching out is is nicknamed the fuel spider. the new design moved the injectors out of the body to enhance reliability among other things. the vortec throttle bodies move no fuel at all just air. what pressure do you get when following the tests below?
http://www.sunlitcomet.com/pdf/auto...96-chevy-tahoe-fuel-pump-pressure-testing.pdf
N
nick8403
I haven't messed with it today but I know I'm getting fuel to the spider but that's where it stops
N
nick8403
Well I know it cause I pulled the lines going into it and far as how much I'm assuming its enough considering my pump checked good and its building up enough preassure that when I went to remove line it shot up and hit the hood
_Dylan_
STAY FROSTY
Did you check for spark? Is it throwing a code?
Is it cranking over like normal, but no start?
retorq
Kingman AZ
:chewie:
Teegrady75
