Goldstreak2874
- Joined
- Mar 10, 2012
- Posts
- 8
- Reaction score
- 0
P0172 P0175 and C0561 stabilitrac, both are constant on this thing and he reset fuel composition
If the engine doesn’t need replacing, why not use those funds to pay off the loan?I have an 07 Suburban with 215,000. We rebuilt the trans 8 months ago. It needs motor mounts, has an oil pan leak. Needs some front end work and struts. We owe about 4,000 on it. Paid off next year. Would you just repair motor mounts or put a reman in? We have the typical oil consumption issue even after changing the gaskets. It has other issues but nothing that I can't deal with right now.
That's the goal. Right now it's in the shop having the compression checked.If the engine doesn’t need replacing, why not use those funds to pay off the loan?
Yes and no, if you drive easy sure you can get by, but.....what about those time when you gotta get on or have to make a quick get away.... i dont want my motor slamming down every time i goose it... good way to break other stuff...electrical connectors, bolts (especially the notorious breaking exhaust manifold bolts) and not to mention torquing the trans, however little bit it may be, point is you are putting added stress on engine bay items that aren’t meant to be stressed that way. Not saying I haven’t driven crs/trucks with broken motor mounts just saying its extra stress on a computerized system that has known problems with grounds, fusebox corrosion...etc. my 2 cts anywayYou can get buy not replacing the motor mounts, however if you do intend to do work on the engine, then might as well do the mounts. Mine were broke and i drove for 75k and recently replaced them when i overhauled the tranny. The rebuilt tranny should last you another 50k-100k.
