fastpat
The copper braids are cheap and easy to replace. You will need to measure the length needed, also easy.
Thanks for the link.If you decide to go the regular copper wire route, I like the website listed below. Its a marine hardware store of sorts. You can buy what ever wire you want, color, size, and length. You can also order different terminals and heat shrink. For an additional small fee, they will crimp the terminals on and install the heat shrink. You receive your wire in the mail and install in your truck. I've used them many times for my boats. Good stuff and good price. I should mention, that most of their wire is tinned copper. Great for the marine environment. I'm not sure if that affects anything for the automotive application.
http://www.genuinedealz.com/
it's called braided cableOn my 23 yr old 97 Tahoe, there are (were) several body to frame copper grounding wires that are an uninsulated copper weave. At least 2 of them are so old and corroded that they broke and are no longer making any ground connection. What kind of troubles might I run into if I don't find a way to re-establish those connections? Any recommendations on where to re-attach/re-establish such grounds?
