Wrong ECM
It may not have the correct calibration for your truck, and you may need to go through the security relearn. Good luck with it; curious to know how it goes.
So, I found an ECU from an '04 Suburban with the 5.3l. It has the same part number as what I "think" my Tahoe is supposed to have, 12586242. Hopefully, other than having the wrong VIN, it will clear up some of the wierd stuff going on, so I can focus on what really needs my attention. I'll try to remember to come back and close the loop on this after I get it. If
It would need to be completely flashed to your vin.
T
Twithers
So I put in the ECM I got online from the '04 Suburban with a 5.3l. I did the 3 cycles of 15 minutes with the key on. The truck started right up the next time. I let it idle for about 15 minutes. Since the ECM came from a different vehicle with all it's own learned info, I disconnected the battery for 15 minutes. Reconnected the battery and took it for a test drive. So far I've found that just the change of ECM corrected all of the throttle problems, passing gears, speedometer accuracy, fuek range calculation and a couple others I can't think of at the moment.
Thanks for the help.
Beefsolar
