Y-pipe debauchery
14SWTahoe
Tampa FL
Final update:
Slip joints are terrible, do not use them for exhaust. As soon as I went flange mounting all my problems disappeared. It was well worth spending the extra 200 bucks to get them welded on.
Driver side
M4_dhQOrjfM7YPYqPZWlqPvNTPunJQwC-chSuESSLlo=w1132-h849-no
Passenger side
YGL8UKQAdcYx1WHInkMEARO9tctmycMnMna295GbQJc=w1132-h849-no
After Y going to muffler
QuDecJJbb05we8Vh7fNDAhM3_xXdUsKawYewOantxac=w1132-h849-no
If anyone goes to LT, deletes cats and does a custom exhaust you are going to need more than one muffler to quiet it down enough to be comfortable.
When I started this, if I knew then what I know now I would have saved about 800 bucks overall. Head my warning and dont make the same mistake I did.
ezdaar
Chat Troll
Redneck central, Aka Houston
Glad you found a shop that can actually weld and knows wtf they are doing.
Nice! but I really hope you thought about a flex joint.
Bruh, I run LT's, no cats, 3" pipe to a single muffler, dumped before axle. the tip is angled 45* out the side in front of rear tire.
Mines only alittle loud at start up, no drone or rasp, nada. just good clean sound.
14SWTahoe
Tampa FL
What muffler did you use?
992dr
Eastern N.C.
The end and final results are very nice.
Sucks you had to go through so much to get here but its definitely worth it.
Single slip joints are no good. Double slips are the way to go. http://www.burnsstainless.com/DSA-2.aspx
Ez,
Why is it such a secret about your muffler?
Having your exit pipe angled out the side instead of coming straight down drastically cuts down on drone.
14SWTahoe
Tampa FL
Ez,
Makes sense, something to keep in mind for next time.
ezmoney1981
