You guys know how I ride... (Z71 Bumpstops inside)
Max
Mile High
Denver
I had no idea your girl stole your testicles Nick, let us know when you get them back so you can mod your truck again.
godoy
utah
So I was doing some cleaning and found these
These are the bumpstops that were removed when truck was lowered!!!
I'll try to install tomorrow if I have time.
Sent from my HTC VLE_U using Tapatalk 2
A
Alex33
That's awesome that you found them. Nothing like free mods :)
Hopefully sometime next week I can get back on mine.
godoy
utah
Ya was going to buy some on Friday not anymore
So should I just thread threw bumpstops hole? My front bracket is shaven off but theirs an existing whole on frame from previous shorty bumpstop
godoy
utah
So I'm at 33 1/4 in rear on both sides and 32 1/4 on front driver and 32 3/4 on front pass. I wanna go for 32 in front but my pass. Bolt is almost completely out and for the rear I have the 4230 springs should I cut them ??
A
Alex33
I would try to thread through the bumpstop.
I wouldn't try to cut the 4230 spring. I gave it some thought but I think that cutting the spring would get you much lower than you want. What's your tire size? I'm at 32" with the same spring but I have a 29.75" OD tire. If you have a tire that has a 32" or greater OD size then you're just as low as me or lower.
godoy
utah
My tire size is a 305 35 24
Is your bolt from pass. Side almost all the way out ?
A
Alex33
My torsion bolts are even.
Edit: It looks like your tire is 32.4" in OD. This means we got about the same drop and your larger wheel/tire combo makes most of the difference. I hope this helps you out. If you really want to trim a spring, go with the 5305s since they have a lot of dead coils and will keep a good ride after they are trimmed.
godoy
utah
I should just get rid of my 24s and get 22s I bet that will help on getting lower
Ill keep that in mind cause the rear is higher!
A
Alex33
Cool deal. Are you in Socal? If so, I'd like to see ur ride in person.
Golden
